Management and Default VLAN
Hi All
I need advice.
At my former office, we used to have another vlan e.g. vlan 10 for management vlan purpose so that we do not use default VLAN 1 to access the switches which i think is good for security purpose.
Now how can I convince my present company that it is the best way to go as they have only vlan 1 for management purposes but then use another vlan say vlan 189 for all unused port which alas, they do not keep to, so invariably, we have ports in vlan 1 and 99 and every where
Is there a doc whereby I can show them why it is best to have a different management vlan from default vlan.?
Re: Management and Default VLAN
Hi Ade,
I believe this link will give you all what you are looking
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml#wp39009
Ankur
*Pls rate all helpfull post
Hi, here is a link that gives a little explanation on Precautions for the use of default management vlan.
Refer to "Precautions for the Use of VLAN 1" section.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml#wp38986
136
