Management Connection incorrect links in CCO.xml?
Does anyone knows how can I update the incorrect links found in the Management Connection? (Tech tips, Troubleshooting & Open Forum Q & A), I've found that the links are written in the file:
C:\Program Files\CSCOpx\htdocs\XML\System\maintree\cco.xml
But even after editing it and reloading the interface, the link is still wrong. Even tried clearing both html and jar caches.
Any info about this?
1 REPLY
Blue
Re: Management Connection incorrect links in CCO.xml?
You have to re-start the JRunProxyServer process for this to get updated. Logout from CW2K completely and close all open browser windows. Update the cco.xml file. From the DOS window, you can do a 'pdterm JRunProxyServer' followed by 'pdexec JRunProxyServer'. Login again and the links should be updated.
96
