Community Member
Management VLAN on Catalyst 3550
If I want to change the management vlan on a catalyst 3550 from vlan 1 to some other vlan, is it simply enough to shut down vlan 1 and create a new vlan, for example vlan 20, and assign it an ip address? Or do I need to configure something else? If so, what and where....?
Thanks! Meg
Re: Management VLAN on Catalyst 3550
Yes..That should do it. No other configuration is neccessary
Community Member
Thanks for the reply! So what happens if I configure 5 vlan interfaces and have int vlan 1 in shutdown. Which one is then the management vlan?
Community Member
Don't forget that there are lots of management traffic that travels only on VLAN1 like CDP, STP etc. My personal experience always have been using VLAN1 as management and everything else in other VLANs.
95
