Management VLAN Question
Greetings,
We have 1 layer 3 switch (4006) and a VTP domain with about 6 VLAN's/Subnets. We have 3 other switches with VTP Trunks to the main switch. We also have about 300 users with about 600 nodes. This include various test environments.
How important is it that we have a management VLAN (VLAN 1 possibly) for connectivity between the switches and other internal network infrastucture devices?
Purple
Re: Management VLAN Question
The recomendation is to normally have a separate vlan for the management domain . Also they recomend not using vlan 1 as the management domain as this vlan is used for VTP updates and a few other functions and you should try to keep any user data off this vlan if possible .
Use the best practice documenation for guidance
http://www.cisco.com/warp/public/473/103.html#second
232
