Managing Routers and gateways from a remote machine and notification
Hi All,
I need to monitor cisco routers and voice gateways from a remote machine ... this is actually an ip telephony setup.
I am new to NMS. Can you please suggest me some sources where i can find some basic information about it.
Thanks & Regards,
Manoj
Blue
Re: Managing Routers and gateways from a remote machine and noti
Are you using any specific NMS application to monitor your IPT setup or planning to use one?
Hi ,
I am planning to use a new one.....if fesible i can use some frewares too?....can u suggest some?
Manoj
Blue
http://www.cisco.com/en/US/products/sw/cscowork/ps2433/index.html is one. Though I'm not aware of any freewares.
Hi mushtaq,
Thanks !!....i will look into it....
what is the role of MIB in this?
Manoj
97
