Community Member
Manejo de Apilibilidad del Catalyst 2948G-l3
Necesito saber cuando va a manejar la stacabilidad el Switch de Layer 3 Catalyst 2948G-L3, ya que actualmente sólo lo hace con GBIC para Fibra .
Community Member
Re: Manejo de Apilibilidad del Catalyst 2948G-l3
traduzca por favor el stacabilidad a los ingleses
Orignial question
I need to know when it is going to handle to the stacabilidad the Switch de Layer 3 Catalyst 2948G-L3, since at the moment only it does with GBIC for Fiber.
Community Member
I need to conection the Catalyst 2948G-L3 in the Backbone with two GBIC WS-3500-XL with two Catalyst 3548 .
Is the possible this? .
FRANKLIN BRIONES
Community Member
The 2948G-L3 has two GBIC ports. You can connect each gig port on the 2948 to each 3500. Don't forget to order GBICs.
http://www.cisco.com/univercd/cc/td/doc/product/l3sw/4908g_l3/ios_12/rel_nts/78_13139.htm#xtocid113955
1000BASE-SX WS-G5484=
1000BASE-LX/LH WS-G5486=
1000Base-ZX extended reach GBIC(singlemode) WS-G5487=
1000BASE-T GBIC WS-G5482
Community Member
I can to connect the Catalyst 2948G-L3 using WS-C5482 with Catalyst 3548 y 2924M-XL, if this use the Module WS-3500-XL for stack .
I wait for response .
Franklin
186
