Webcast-Catalyst9k
Many remote users connecting through ISDN with the same username receive the same IP address
Is it normal that many remote users connecting through ISDN with the same username receive the same IP address?
We have a router with a PRI interface for remote access to the office.
By default, all the remote users are using
the same "username" and "password" pair when connecting through ISDN.
An "ip local pool" is also configured for the remote users to get an IP address.
The problem is that every user get the same IP address from the "ip local pool".
In other words, if two or more users use the same "username/password" pair they get the same ip address !!!
Question 1: Is it normal?
Question 2: Can we change this behaviour?
Router configuration:
interface Serial1/0:15
no ip address
encapsulation ppp
no ip route-cache
dialer rotary-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
no cdp enable
interface Dialer1
ip unnumbered Ethernet0/0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 1800
dialer hold-queue 10
dialer-group 1
peer default ip address pool pool_isdn
no cdp enable
ppp callback accept
ppp authentication chap pap callin
ppp multilink
ip local pool pool_isdn 172.16.201.151 172.16.201.199
1 REPLY
Anonymous
N/A
Re: Many remote users connecting through ISDN with the same user
You need to add these commands under the dialer interface:
ppp ipcp ignore-map
dialer mult-map-same-name
129
