Community Member
Mapping MPLS LSP to a PVC on an interface
i want to make L2 VPN between two cisco routers,or between a cisco router and another vendor router,i want to map a pvc on the Cisco router to an MPLS LSP and do the same mapping at the other end of the LSP, so i can have as LSP tunnel that carries L2 pvc information for a customer.
1 REPLY
Re: Mapping MPLS LSP to a PVC on an interface
You can tunnel L2 information over MPLS using MPLS ATOM (Any transport over MPLS).
Layer 2 tech can be FR,HDLC,PPP or any supported platforms. You need to have Layer-2 tag switching enabled on your core.
Refer the below URL,
http://www.cisco.com/warp/public/cc/so/neso/vpn/unvpnst/atomf_ov.htm
193
