MAX GEIPs in 7500 series routers
What is the maximum number for GEIPs not GEIP+ that can be inserted and function on the 7500 platform. I am trying to use a 3rd GEIP and it enables but I can't ping through the interface.
  • Other Network Infrastructure Subjects
Silver
Re: MAX GEIPs in 7500 series routers
Depending on the 7500 platform (e.g 05/07/13) you should be able to fully populate the router, in non-RSP slots (e.g. 1 -5 and 8 -12 in a 7513, although My Cybus would be at 234% capacity), with GEIPs. **NOTE: The CyBus in 75xx series routers is 2X1Gig so, although it will work, the Cybus can be oversubscribed easily with these cards. I'd check to ensure this card is passing diagnostics and functioning properly (e.g. Not wedged, etc) and check your configuration and your physical connection (Both RX and TX) to whatever you're trying to ping to.
Hope this helps,
Don
Thanks for the information. I am going to work with TAC on as to why the interfaces would come up/up but could not ping across.
95
