Max number of VLANS on a 3500 switch
IS there a maximum number of VLANs on a 3550 switch
Bronze
Re: Max number of VLANS on a 3500 switch
But only 128 STP instances supported.
"If more VLANs are defined in the VTP than there are spanning-tree instances, you can enable STP on only 128 VLANs. The remaining VLANs operate with spanning tree disabled. If the number of VLANs exceeds 128, we recommend that you enable the MSTP to map multiple VLANs to a single spanning-tree instance."
See http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12112cea/3550scg/swstp.pdf
for details.
Milan
102
