You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Max Supported Memory 2511
How can I tell How much I have and how much more I need to max it out by looking at the output below?
thanks !!
Access-Server#sh ver
IOS (tm) 2500 Software (C2500-C-L), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 14:39 by dchih
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTLDR: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
Access-Server uptime is 25 minutes
System returned to ROM by reload
System image file is "flash:c2500-c-l.123-26.bin"
cisco 2511 (68030) processor (revision L) with 14336K/2048K bytes of memory.
Processor board ID 06114071, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
  • Other Network Infrastructure Subjects
Hall of Fame Super Gold
Re: Max Supported Memory 2511
14336K/2048K bytes <--- This is your DRAM.
16384K <--- Flash.
No you can't upgrade ANYTHING on a 2500 router. Practicing on an ancient appliance like this is a waste of time. Go look for an 1800 or something from the ISR G1 is probably worth it.
Sent from Cisco Technical Support Nintendo App
Thanks Leo!!
What would you suggest as a Access Server ?
Thanks!
Access SERVER????
You want to use the 2511 as a console server? Check WTI.
307
