Webcast-Catalyst9k
Maximum console cable length with UTP CAT 6A
I would appreciate any advice on what is the maximum length of a console cable connecting a Terminal Server and a router, being that the cable is built with UTP CAT 6A and RJ45 connectors. Would a 30m cable work?
Many thanks in advance.
Re: Maximum console cable length with UTP CAT 6A
Hello ,
Personaly i would try to build one . I use a console cable of 10m and i have no problem.
Dan
I have seen cables upwards of 300m at slow speeds.  It depends on the cable and the quality of the transciever at the receiving end.  I suspect 30m will work flawlessly.
Great, many thanks for your answers.
1538
