Community Member
Maximum Inrush current for Catalist 6500 power supply 1000W
I need to find maximum Inrush current in amperes for Catalist 6500 power supply 1000W, because I have problem when I connect to UPS . There nothing about this in Catalyst documentation.
1 REPLY
Silver
Re: Maximum Inrush current for Catalist 6500 power supply 1000W
think you are mentioning about the maximum ampere current rating to which the Cat 6500 can be connected. Below is the listed
The 950 W power supply requires a 15 A circuit.
The 1000 W power supply requires a 15 A or 20 A circuit.
The 1300 W and 2500 W power supplies require a 20 A circuit.
The 4000 W power supply requires a 30 A circuit.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/inst_aug/02prep.htm#1020475
185
