Maximum number of switches between two endpoints ?
I know there's a limit concerning the number of switches between two endpoints used in a STP enviroment, but is there a "Cisco" document describing this issue ?
Re: Maximum number of switches between two endpoints ?
Or you can check out the IEEE 802.1d & 802.1w specs, these state that the maximum diameter (The maximum bridge diameter of the Bridge LAN: The maximum number of Bridges between
any two points of attachment of end stations) as 7:
This document gives several answers on frequently asked questions for PFRv3 channel state behavior.
Q1: What are all the channel operational states from a BR (border role) perspective and what are the rules/conditions to be in each st...
view more
Symptoms
The need was to reach an host inside a LAN through a VPN connection managed by the LAN gateway (Cisco 1921).
The LAN gateway performs NAT and there was a dedicate nat rule for the host i wanted to reach through VPN.
I couldn't connect to the hos...
view more
We have 3 identical switches configured by someone else and would like to claim some of the Gigabit ports(G1/G2/G3/G4) for use on servers. When we try to change the wiring and configuration, we run in to connectivity issues. Attached is a des...
view more
