Maximum recommended bandwitdh usage for 100 Mbps links
Hi all,
A co-worker told me yesterday that the maximum recommended bandwidth usage for a 100 Mbps Fast Ethernet link is only 30%. I think that is too low.
Who is right?
Thanks in advance.
Re: Maximum recommended bandwitdh usage for 100 Mbps links
By the way, I mean 100 Mbps on a switched interface.
Sergio.
Purple
I would flatly disagree with that , you can run a full duplex link probably to 80-90% without a problem . This used to be the limit on old 10 meg half duplex hubs . Above 30% you would start to see a fast drop off in performance.
Hi Glen,
Thank you very much for your answer. I supposed 30% was an extremely low value.
Last question: what would be the recommended value for an 100 Mbps Ethernet network? I mean for a VLAN segment for example.
Thanks again Glen.
Sergio.
Sergio,
As such you can make any number of vlans as suported on the switch and depends on your whole N/W design or requirement. You can have as many clients/host in a particular Vlan and you wont see any performance impact unless you have a host whihc is generatiing real bad traffic like broadcast or any host with bad NIC.
revert if you more questions.
regards
-amit singh
Hi again,
So, I could have a switched network that is being used all the time at about 70-80% (with normal user traffic) of its maximum bandwidth, and the network won't be degradated at all.
Right?
Thanks.
218
