MC3810-DVM-t1 Card or MC3810-AV6-Card
Hi Tejal
Can I use the PBX feature in MC3810 Card using either AV6 or DVM-T1 module.to deliever audio service from a internal remote location to the Remote internet user using VPN..
Rajendra
CGN
1 REPLY
Re: MC3810-DVM-t1 Card or MC3810-AV6-Card
You can use the E&M card on the AV6 card to interface the PBX, if you have E&M support on the PBX. Otherwise you can run ISDN QSIG or other proprietary signalling (check for the ones supported by Cisco) on the DVM-T1 module to interface the PBX.
158
