MC3810 , frame relay and large ping packets
We are not able to send large ping packets say anything above 13000 bytes
The out drop queue on the serial starts increasing. There is no problem sending small ping packets i.r anyhting below 15000. As per my undertanding it should frgament them and send but its not happening. Could it be a layer 2 issue?
Building configuration...
Current configuration : 5694 bytes
! Last configuration change at 12:01:29 BST Mon Jul 14 2003 by williapa
! NVRAM config last updated at 12:01:31 BST Mon Jul 14 2003 by williapa
version 12.1
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname w7scs02
logging buffered 65536 debugging
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa accounting commands 15 default start-stop group tacacs+
enable secret 5 <removed>
enable password 7 <removed>
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
network-clock base-rate 64k
ip subnet-zero
no ip domain-lookup
frame-relay switching
interface Ethernet0
description Corporate LAN - WAN Interconnect Segment
ip address xxx.xxx.57.2 255.255.255.0
no ip route-cache
no ip mroute-cache
ntp broadcast client
interface Serial0
description 128K ( bandwidth 128 )
ip address xxx.xxx.46.250 255.255.255.252
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
load-interval 60
no fair-queue
cdp enable
frame-relay map ip xxx.xxx.46.249 202 broadcast
frame-relay interface-dlci 202 voice-encap 80
frame-relay intf-type dce
hold-queue 1024 in
hold-queue 1024 out
interface Serial1
description Serial1 - Unused
bandwidth 64
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
interface Switch0
no ip address
no fair-queue
router eigrp 20
network 147.201.0.0
network 192.168.46.0
auto-summary
eigrp log-neighbor-changes
no ip http server
no ip classless
ip access-list extended EURO-Alert
permit tcp any any eq www log
permit ip any any
ip access-list extended InVirusFilter
deny ip host xxx.xxx.240.191 host xxx.xxx.184.158
deny ip host xxx.xxx.240.191 host xxx.xxx.184.154
deny ip host xxx.xxx.17.207 host xxx.xxx.184.158
deny ip host xxx.xxx.17.207 host xxx.xxx.184.154
permit ip any any
ip access-list extended OutVirusFilter
deny ip host xxx.xxx.184.158 host xxx.xxx.240.191
deny ip host xxx.xxx.184.154 host xxx.xxx.240.191
deny ip host xxx.xxx.184.158 host xxx.xxx.17.207
deny ip host xxx.xxx.184.154 host xxx.xxx.17.207
permit ip any any
ip access-list extended WebVirusBlock
deny tcp any any eq www
deny tcp any any eq 8080
permit ip any any
no logging trap
1 REPLY
Silver
Re: MC3810 , frame relay and large ping packets
There are a few bugs logged against ping's above the fragment size failing with FRF.12. Check if any of them match your problem. Please also try using the 'show frame-relay fragment' command with the interface and dlci included. The following doc talks about FR fragmentation for Voice.
http://www.cisco.com/warp/public/788/vofr/fr_frag.html
83
