Webcast-Catalyst9k
Memory allocation problem on Cisco 3640 Router
Dear Sir,
We are getting the following error on our Cisco 3640 Router.
-Traceback= 6042E3C8 6042E604 6051EF4C 604B3084 604B31EC 604012BC 604012A8
Sep 19 01:03:50 GCC: %SYS-2-MALLOCFAIL: Memory allocation of 12000 bytes failed from 0x60433164, pool Processor, alignment 0
-Process= "TCP Protocols", ipl= 0, pid= 37
GCC_Peering#show version
IOS (tm) 3600 Software (C3640-I-M), Version 12.2(2)T4, RELEASE SOFTWARE (fc3)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 09-Feb-02 22:10 by yiyan
Image text-base: 0x600089A8, data-base: 0x60AA4000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Show Version:
GCC_Peering uptime is 9 weeks, 4 days, 20 hours, 48 minutes
System restarted at 14:43:46 GCC Wed Jul 13 2005
System image file is "flash:c3640-i-mz.122-2.T4.bin"
cisco 3640 (R4700) processor (revision 0x00) with 25600K/7168K bytes of memory.
Processor board ID 26455338
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
4 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
2 Serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Waiting for your reply
Thanks/Regards
Atul
1 REPLY
Re: Memory allocation problem on Cisco 3640 Router
Have u enabled CEF in your router ? is it running already in place ?
we did place some problems due to some worms,virus issues also would suggest to check out whether blaster or nachi or their variants creating some kinda traffic which mite also result u up in this kinda of error message.
do refer this links also for more info ..
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_security_notice09186a00801aedd6.html
http://www.cisco.com/en/US/products/products_security_advisories_listing.html
regds
151
