Community Member
Memory usage problem on X25 links
We have a problem about X25 configuration. We are using PAD connections on an X25 network. Every PAD connection uses about 1k buffer memory. Although the PAD connection is terminated, the buffer is not freed.So after 17000 PAD connections, we get "%No more memory available" error and new PAD connections cannot be established unless we reload the router. I am not experienced on X25 and PADs.So are there any missing commands on the configuration below?
And I am using c2600-i-mz.121-2 IOS.I can upgrade the IOS if this problem is caused by a bug.I am waiting for your comments.
Thanks.
Using 2717 out of 29688 bytes
version 12.1
service timestamps log uptime
hostname 2600
enable secret 5 $1$.YWA$ySJMb/f8IJvXqcIiKhiR3/
ip subnet-zero
x25 routing
interface Ethernet0/0
ip address 192.168.10.1 255.255.255.0
interface Serial1/0
bandwidth 64
ip address 10.0.0.2 255.0.0.0
encapsulation x25
x25 address xxxxxxxxxx
x25 htc 10
x25 t20 60
x25 t21 180
x25 t22 60
x25 t23 60
x25 idle 2
x25 nvc 6
x25 map ip 10.0.0.1 xxxxxxxxxx
x25 map ip 10.0.0.10 xxxxxxxxxx
x25 map ip 10.0.0.12 xxxxxxxxxx
x25 map ip 10.0.0.250 xxxxxxxxxx
pulse-time 1
no cdp enable
lapb interface-outage 15000
lapb N2 10
interface Serial1/2
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip classless
ip route xxx.xxx.xxx.xxx 255.255.0.0 10.0.0.250
ip route 192.168.1.0 255.255.255.0 10.0.0.1
ip route 192.168.100.0 255.255.255.0 10.0.0.10
ip route 192.168.102.0 255.255.255.0 10.0.0.12
no ip http server
x25 route xxxxxxxxxx interface Serial1/0
line con 0
transport input none
line aux 0
line vty 0 4
password 2600
login
exception memory fragment 10000
exception memory minimum 10000
end
1 REPLY
Silver
Re: Memory usage problem on X25 links
12.1.2 had actually been deffered for other reasons in other platforms but the recommended "goto release" was 12.1.5 at the time. 12.1.17 is GD and works very well. My customer uses X25 with this 12.1.17 code with no memory leak problems, you've mentioned, to speak of.
Hope this helps,
Don
87
