Message "ERROR: could not add peer" when setting max-dn for SRST
I have a 3660 router that I am attempting to configure SRST on. When I go under the call-manager-fallback section and issue the "max-dn 160" command, I get 131 messages back saying "ERROR: could not add peer". Any ideas what might be causing that?
Re: Message "ERROR: could not add peer" when setting max-dn for
How many dial peers do you have? It could be due to memory limitations. Do you see the following message in the log?
DIALPEER_DB-3-ADDPEER_MEM_THRESHOLD: Addition of dial-peers limited by available memory
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122sup/122sems/semsvol1/emfdbus.htm#xtocid7
Yes, I do see that message. The router has 64MB of memory. Is there a document that describes how much memory is needed for a particular number of dial peers?
The router won't allow you to add more dial-peers (and therefore consume more memory) if more than 75% of available processor memory is used up (you can get the amount of processor memory via the 'show mem sum' command).As a workaround, try lowering the IO memory resulting in more Processor memory.
1848
