Community Member
MGX-8850. Card not present, still able to cc
1. Is is a real surprising. Card is not at all prsent in the slot x, but still when i do cc x, It shows me the prompt of x. what could be the reason?
2. I have inserted a new front VISM card and it is always showing in standby/active. Can someone suggest that why it is always going in "standby mode". Getting follwing message when I reset the card"ACRED: Upload BRAM Failed
Error occurred while uploading the SM configuration file to the ASC disk."
I am getting error meaage while doing setrev
" SHM LSM ERR: ssiMsgSend failed in function pmmSendPresenceNotification, return
code 3997698
08A05674 01/20/2004-09:22:58 FILM-7-SM_FW_DNLD_PASS
tRedDownloatRedDownloadFw"
Can you help?
Re: MGX-8850. Card not present, still able to cc
Can you give the following display commands ?
dspcds
dspred
Also include the following part of the log
dsplog -sl x ( where x is the slot you have the card in).
Community Member
Sorry, I can't capture the same as I have moved the card to different slot. But when the card was in actual slot I got few messages
1. ACRED: Upload BRAM Failed
2. Msg rxd after setrev
08A05678 01/20/2004-09:22:59 RED-7-TBL_UPD_INFO
tRed processPMMcardFailureFo
tRed INFO: In processPMMcardFailureForSM at 1635, redTable is being updated
08A05677 01/20/2004-09:22:59 RED-7-SMM_INFO
tRed redSMstateMachine
System Information : slot=14, event=12, present_sm_state=1
08A05676 01/20/2004-09:22:59 SHM_-7-UNRES_CD_REMOVE
ShelfMgr shmCsmCdRemoveLog
SHM INFO: Unreserved Card removed at slot 14
08A05675 01/20/2004-09:22:59 SHM_-5-LSM_SSI_MS_ERR
ShelfMgr pmmSendPresenceNotifica
code 3997698
3. ACRED: Upload BRAM Failed processGoDefaultRespMsg upLoadBram failed after go
default , slot 10
4. Slot 10 :: SM Error: upLoadBram: sysNvRamGetRmt failed
90
