Webcast-Catalyst9k
MIBS FOR DEVICES
Can anyone tell me where I can get mibs from, I cant ftp to the cisco site, can you do anything on the actual device to get anything off, or is there another site I can use ?
thanks
Re: MIBS FOR DEVICES
You can use the show snmp mib command and its extension to your use.
Also you can check this lihttp://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtmlnk.....
Rgds,
Naveen
All I need is a mib for the 2950 switch for my observer software suite, So that I can monitor the switch performance and see whats plugged into it, What do I need for this, I cant find anything ?
thanks
Try the bridge mib. Also note that all objects in this mib may not be instrumented, in which case you would have to get info via cli.
Can this be used for all my switches then ? will this tell me whats plugged into the switch etc ?
114
