Webcast-Catalyst9k
Microsoft RIS builds won't work with CISCO switches
Help, when we try and do machine builds with CISCO switches any model it will not work. Has anyone had any similar problems with this in the past?
We have tried putting portfast on and taking it off
Re: Microsoft RIS builds won't work with CISCO switches
Is any L3 device involved or are you trying just locally in the same subnet (connected to the same switch ideally)?
Milan
it is a 3550 with two vlan's in different subnets on it
however the RIS builds would all take place on the same subnet
Did you try turning of spanning tree on the port the PC's are connected to?
sorry i see you have tried that.
186
