MiLAN converter problem? 2950G incompatibility?
Hi there, here's whats happening.
I've a new 2950G switch, with a new fibre gbic in slot 1. A working mmf fibre pair (3 metres) is connected to this. This is, in turn, connected to a new MiLAN 6113 SX media converter.
By way of testing, I've connected a server with a gigabit nic and a working cat5e cable to the UTP port of the converter.
The problem I'm having is: I just cannot get a link on the 2950G via the converter.
I've tested the following:
-'loopback', by connecting the rx and tx ports on the gbic via the same fibre strand. This detected a link straight away, then, as expected, closed it when the keepalive packet was detected.
-While doing the loopback test, I've alternated the fibre strand to check both fibres are good. Works ok, loopback is detected.
-The converter shows the following info:
->power on.
->fibre side shows 'link' light.
->copper side shows '1000', 'lnk/act', and 'fdx/col' lights.
BTW, I've updated IOS to 12.1 (19)
Other findings:
Interestingly, the console on the switch does not flag anything when the fibre gbic is inserted, although it does when a copper one is inserted. Strange. The cisco chap I spoke to about it said this was nothing to worry about.
'SH INT STATUS' shows '1000 BASE SX' in slot g0/1.
'SH INT G0/1' does not show anything 'new' when the gbic is inserted than when its removed.
I really cant think of anything else I can test/check- anyone have any ideas?
Thanks-
0r8it
135
