Minimum Speed on a VIP4-50 in PA-4T
I'd like to find out what is the minimum speed of the VIP4-50 in serial interface(PA-4T) on a Cisco 7500
Router#sh ver
IOS (tm) RSP Software (RSP-JSV-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 03-Jan-03 17:56 by ccai
Image text-base: 0x60010948, data-base: 0x61F04000
ROM: System Bootstrap, Version 12.0(10r)S1, RELEASE SOFTWARE (fc1)
Router uptime is 46 weeks, 2 days, 20 hours, 59 minutes
System returned to ROM by reload at 15:24:14 UTC Fri Apr 11 2003
System restarted at 00:36:05 KOREA Sat Apr 12 2003
System image file is "slot0:rsp-jsv-mz.122-13.T1.bin"
cisco RSP8 (R7000) processor with 262144K/8216K bytes of memory.
R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
3 FEIP2 controllers (6 FastEthernet).
1 VIP4-50 RM5271 controller (4 Serial).
4 VIP4-80 RM7000 controllers (2 GigabitEthernet)(2 HSSI)(1 POS).
6 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
2 HSSI network interface(s)
1 Packet over SONET network interface(s)
2043K bytes of non-volatile configuration memory.
32768K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
20480K bytes of Flash PCMCIA card at slot 1 (Sector size 128K).
16384K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 7 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
Compiled Fri 03-Jan-03 13:40 by ccai
Slave: Loaded from system
Slave: cisco RSP8 (R7000) processor with 262144K bytes of memory.
Configuration register is 0x102
----------------------------------------------------Router#sh diag
Slot 10:
Physical slot 10, ~physical slot 0x5, logical slot 10, CBus 0
Microcode Status 0x4
Master Enable, LED, WCS Loaded
Board is analyzed
Pending I/O Status: None
EEPROM format version 1
VIP4-50 RM5271 controller, HW rev 2.01, board revision A0
Serial number: 22619471 Part number: 73-4708-02
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 31 02 01 01 59 25 4F 49 12 64 02 00 00 00 00
0x30: 50 05 35 00 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x4 Insertion time: 0x1CFBF8C54 (33w3d ago)
Controller Memory Size: 256 MBytes CPU SDRAM, 64 MBytes Packet SDRAM
PA Bay 0 Information:
Mx Serial PA, 4 ports
HW rev 1.14, Board revision B0
Serial number: 25252478 Part number: 73-1577-07
--Boot log begin--
IOS (tm) VIP Software (SVIP-DW-M), Version 12.2(13)T1, RELEASE SOFTWARE (fc1)
Compiled Fri 03-Jan-03 13:45 by ccai
Image text-base: 0x60010930, data-base: 0x604C0000
--Boot log end--
What command can I use to find this out?
Re: Minimum Speed on a VIP4-50 in PA-4T
use the
show controller command for information about the card connections.
show interface for interface in question
more information on the PA-4t can be found that this url:
http://www.cisco.com/en/US/partner/products/hw/modules/ps2033/products_module_installation_guide_book09186a008007dede.html
Thank you for your reply.
91
