03-20-2006 01:07 AM - edited 03-03-2019 02:22 AM
I have a problem with a Catalyst 6509 switch.The problem initially I had was loggin into the switch.I was always sent to the rommon> anytime I tried logging into the switch until I was told to enter "boot bootflash:". I was able to enter the switch but could not find the FWSM module.The module was there until we tried upgrading the IOS of the MSFC.
When I enter "show module" it does not show the FWSM module.
Is there something anybody can please show me to do other to access the Firewall module.
03-20-2006 02:01 AM
Please paste the show version from the switch. Did u ever work on the FWSM. Were you able to get it prior the IOS upgrade.
Which Sup you are running and the IOS ??
Please look at the system requirement for deploying FWSM:
SYSTEM REQUIREMENTS
Cisco Catalyst 6500 Series Supervisor Engine 2 with Multilayer Switch Feature Card 2 (MSFC2) or Cisco Catalyst 6500 Series Supervisor Engine 720
Native Cisco IOS Software Release 12.1(13)E or later. If you are running a Supervisor Engine 720, you will need Cisco IOS Software Release 12.2(14)SX or later
Hybrid Cisco Catalyst OS Software Release 7.5(1) or later. If you are using a Supervisor Engine 720, you will need a minimum of Cisco Catalyst OS Software Release 8.2
If you intend to use the multi-SVI feature, you will need Cisco IOS Software Release 12.2(20)E or later for native Cisco IOS Software, and for Cisco Catalyst OS software you will need version 7.(6) or later
Occupies one slot in a Cisco Catalyst 6500 Series Switch or Cisco 7600 Series Router
Up to four firewall modules may be deployed in the same chassis
You have a console on the FWSM, did u try accessing it. Is it in rommon. This could be a problem with the FWSM, pls check.
HTH,Please rate if it does.
-amit singh
03-20-2006 03:33 AM
Thanks for your post.
Below is the result of a sh version and sho module of the switch as well as a report that comes up upon bootup using the "boot bootflash:"
core02>en
Password:
core02#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(12c)E4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 14-Oct-02 12:37 by hqluong
Image text-base: 0x40008980, data-base: 0x41598000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(12c)E4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
core02 uptime is 4 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:c6sup22-psv-mz.121-12c.E4.bin"
cisco Catalyst 6000 (R7000) processor with 227328K/34816K bytes of memory.
Processor board ID SAL08144260
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
8 Ethernet/IEEE 802.3 interface(s)
--More-- 6 Virtual Ethernet/IEEE 802.3 interface(s)
26 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
core02#sh module
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL08154S4S
2 8 unknown FRU type (major = 0x6003, mino WS-XSVC-K+BB-2 SAD081203ZV
3 16 16 port GE RJ45 WS-X6316-GE-TX SAD08140999
4 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL081555Q1
Mod MAC addresses Hw Fw Sw Status
1 000f.8f9d.3510 to 000f.8f9d.3511 5.0 6.1(3) 7.2(0.90) Ok
2 000f.8f5b.bd62 to 000f.8f5b.bd69 2.0 Unknown Unknown PwrDowo 0003.feae.f137 1.3 5.4(2) 7.2(0.90) Ok
4 000f.f716.8dd0 to 000f.f716.8dd7 3.1 5.4(2) 7.2(0.90) Ok
Compiled Mon 14-Oct-02 13:00 by hqluong
00:00:54: %SNMP-5-COLDSTART: SNMP agent on host core02 is undergoing a cold star
t
00:00:56: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 2, power not allo
wed: Unknown Card Type.
00:00:56: %C6KPWR-SP-4-ENABLED: power to module in slot 3 set on
00:00:57: %C6KPWR-SP-4-ENABLED: power to module in slot 4 set on
00:01:10: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimum Online Diagnostics..
00:01:14: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
00:01:14: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
00:01:25: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimum Online Diagnostics..
00:01:28: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
00:01:28: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
00:01:56: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimum Online Diagnostics..
00:01:57: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
00:01:57: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
Mod Sub-Module Model Serial
03-20-2006 04:12 AM
The IOS that you are running on your Switch is 12.1(12c)E4 and the minimum IOS require for this module to get recognize and work is atleast 12.1(13) E or later. Please upgrade the IOS and you will be all set to go.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/ol_2310.htm#wp1193658
Please look at the release notes above.
HTH, Please rate if it does.
-amit singh
03-20-2006 10:34 AM
I now have c6k222-psv-mz.122-18.SXD7.bin
how do I upload this to my Catalyst switch ?. The switch is IOS based
Is it copy tftp flash or do u know some other way?
03-20-2006 10:38 PM
You an upload the same using copy tftp command itself ,once you are done with your upload you can change the bootvariable using the bootsystem command pointing the new ios code,but do remember to remove the existing one before adding the new bootvariable.
regds
