Missing flash in 2900XL; what class of flash is it, anyway?
While updating IOS in a bunch of 2900XL switches, I saw the following:
b7122r59B-wg-2924C-1-v1#sho ver
IOS (tm) C2900xl Software (C2900xl-C3H2S-M), Version 12.0(5)WC5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 28-May-02 11:11 by devgoyal
Image text-base: 0x00003000, data-base: 0x0034A3C8
ROM: Bootstrap program is C2900xl boot loader
b7122r59B-wg-2924C-1-v1 uptime is 7 minutes
System restarted at 14:44:33 EDT Sun Jul 14 2002
System image file is "flash:c2900xl-c3h2s-mz.120-5.WC.bin"
cisco WS-C2924C-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
Processor board ID FAA0308J0TG, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:50:80:70:7E:00
Motherboard assembly number: 73-3381-04
Power supply part number: 34-0834-01
Motherboard serial number: FAA03069H6T
Model revision number: A0
Model number: WS-C2924C-XL-A
System serial number: FAA0308J0TG
Configuration register is 0xF
b7122r59B-wg-2924C-1-v1#dir flash:
Directory of flash:/
2 ---x 1798272 Jan 01 1970 09:24:15 c2900xl-c3h2s-mz.120-5.WC.bin
20 ---x 333 Dec 31 1969 22:16:54 env_vars
6 ---x 108 Jul 14 2002 12:39:43 info
16 -rwx 8192 Jul 14 2002 12:42:37 e2rb.bin
181 ---x 108 Jul 14 2002 12:42:37 info.ver
17 -rwx 2423 Jul 14 2002 12:43:26 config.text
3612672 bytes total (1800704 bytes free)
Thus, it claims to have 8M of flash, but dir flash: only reports a total of 5413376 bytes. Where did the rest go?
Also, is there a good reference for the 2900 and 3500 XL file system commands? The "Using the Cisco IOS File System" doc talks about Class A, B, and C Flash File Systems, but doesn't include the "red-headed IOS" version in the switches.
Re: Missing flash in 2900XL; what class of flash is it, anyway?
The XL has 8MB DRAM and not 8MB flash. It has approximately 4mB flash and not 5413376 bytes as you mentioned. Document for reference
http://www.cisco.com/warp/public/473/36.shtml#Memory
I must have passed by that reference a dozen times, but made the leap from "8MB" to "flash" each time, blissfully skipping over "DRAM". What started all this was that the published update procedure failed when it ran out of flash. I assumed I didn't have enough flash, and went looking for a reason to justify that assumption. I'll read more carefully in the future; thanks.
103
