Missing interface
I have a 3548 XL switch which has a Gigabit Ethernet interface missing when I do a 'show version'. It reports I have only got 1 but there should be 2. What has happened to the other one? Has the config lost it? Can I get it back?
Craig
Silver
Re: Missing interface
If show version doesn't show the other Gbic interface, that Gbic interface maybe bad. Replace it with a spare Gbic module, and see the sh version.
There was no GBIC interface in the slot but I have put one in now and it just comes up with an Amber LED. Any ideas? Can the slot be replaced?
Amber LED means blocked port (via STP probably).
Use sh span on the interface to see what's going on.
Milan
I can not do a sh span on the interface because it does not reconise the interface Gi0/2! It works OK on Gi0/1 and the fastethernet ports.
Hi Craig
After the series of trials could you also mention the IOS version of the switch.
The problem could also be related to the IOS version of the switch.
If that be the case then CSCdp57240 should give better results.
PS: Have you tried the working Gigabit Module in the second port which is not coming up and if so what is the result.?
Vatsan
The IOS version is IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE.
I have tried the working module in the other port (Gi0/1) and it works fine.
228
