Mistake on setting interfaces default
willfachi
This is the scenario: Router 2600
I have a serial port configured as follows:
interface Serial0
description Test 56 kbps Circuit #TEST-New
ip address 10.20.1.1 255.255.255.224
ip route-cache
ip mroute-cache
bandwidth 256
no shutdown
ipx network BBOQ1155
________________________________________
How do I wipe out all information on the serial interface and set the interface back to factory defaults (i.e. empty) with one command? I have a lot of routers that need to be reset and this would help a lot.
tia
regards,
cro9uk
from enabled mode type "setup" and this should trigger the setup wizard.
cro9uk
depending on how new your ios is, you can also type in "default interface serial 0" from the config prompt
Rowan
