Community Member
mlppp and IP Cef
I have two routers that are joined by a mlppp bonded T1x2 for a total of 3MB. At the moment we only utilize about half the bandwidth. Do you think Multilink Interleave and Fragmentation are necessary?
Also, should I not be running IP CEF on these two routers? Each router has an additional serial interface to other networks.
TIA
1 REPLY
Re: mlppp and IP Cef
For voice traffic interleave is usefull So if there is voice traffic no mater how much bandwidth is utilze I would recommend to turn on interleave and fragmentation . Also you can turn on CEF .
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800b75d2.html
Nilesh
104
