MLS and Netflow on Cat 4006 with Sup.II
Gnetlemen
I read the following off of the PSIRT site:
Using CatOS with Sup2 and MLS to Detect Infected Hosts
MLS statistics can help track down infected hosts. NetFlow should be enabled in full flow to see source and destination ports, as in the following example, which shows traffic sourced from infected hosts, attempting to infect random systems on destination port tcp 135.
I tried to set the command "set mls flow full" but it barfed it... I then did a "set ?" and mls does not seem to be a feature on my Sup. II? Do I need to upgrade the code? I think it is at 7.1.2 ...
1 REPLY
Bronze
Re: MLS and Netflow on Cat 4006 with Sup.II
The command is meant for a catalyst 6500 supervisor2 , not a catalyst 4000 supervisor II. The catalyst 4000 supervisor II does not support MLS.
108
