eap
mls flow full
We have a 6509 that I applied the command, set mls flow full, to yesterday as suggested by the TAC article for looking for the Nachi worm. I want to get rid of that command but am not sure how. I like the IOS where to negate a command you simply say no and repeat the command. Not so with CatOS.
Any help would be appreciated,
Paula
Re: mls flow full
If you do not have access lists on any MLS-RP, the default flow mask is destination flow. You can change it using command
Console (enable) set mls flow ?
destination Set flow type Destination only
destination-source Set flow type Destination and Source
full Set flow type Full
Console (enable) set mls flow destination
Configured IP flowmask is set to destination flow.
eap
Re: mls flow full
Is that a default setting because that command was not in our previous non-default configuration?
Paula
Re: mls flow full
Yes
98
