Mobile IP - home network relative to home agent
Is there any requirement that a home network for mobile nodes must be directly attached to a home agent router? I have assumed that a mobile node on its home network can be reached from a home agent using routing as usual, when the home agent has no mobility binding. When a home agent establishes a mobility binding, the home agent intercepts packets destined for the home network, encapsulates them, and routes them to a care-of address based on the routing table. Is this correct? What configuration issues must be addressed when the home network is not directly attached to the home agent?
Mike
1 REPLY
Re: Mobile IP - home network relative to home agent
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
158
