Modem banner/exec banner problem - Urgent
Hi people,
We got 3725 and 2610XM with NM-8AM's in them. We have old IBM RS6000 machine dialing into these routers. The RS6000 expect the router name as part of the inital connect message : ie RS6000 dials into a router called NewYork. After the hand shake phase, the RS6000 expects NewYork before it will kick off it's PAP/Chap stuff.
I had this working on a Cisco loan 3660, however now that I have transfered the configs to the enw routers, I have to hit the enter key before I get any prompt. I have looked into the actiation-character command, but can't figure out how to set it such that the exec-banner or whatever can display the router name.
Here is part of the config :
interface Group-Async2
ip unnumbered Loopback0
encapsulation ppp
ip tcp header-compression passive
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
no peer default ip address
no keepalive
ppp authentication chap pap callin
group-range 129 136
exec-banner ^c NewYork ^c
line 129 136
flush-at-activation
modem InOut
transport input all
autoselect during-login
flowcontrol hardware
Cheers,
Gordon
gordon.p@cleardata.com.au
1 REPLY
Silver
Re: Modem banner/exec banner problem - Urgent
Why don't you try putting back the box with which it worked and check if it's still working. If it still works, then check the configuration of the new boxes. If it doesn't work, then you know it's a probelm with the RS6000.
105
