Modemcap entries and retrains on 2620.
I'm looking for the correct Modemcap entry for NM-8AM modems on
2620 to limit the connect speed to 14.4kbps. Any way of changing some of the S registers or putting in a different init string?
On that point a further modemcap question: Is there a setting to increase
the number of accepted retrains/negotiations?
At the moment the number seems to be fixed at 3, is there a way to increase it to a higher number like 10? Due to the bad lines in the area many customers modems are kicked off, leading to a 'no-connect'.
By increasing the number of retrains and limiting the speed we are hoping to get better results.
Thanks.
Lutz.
1 REPLY
Re: Modemcap entries and retrains on 2620.
Here is the docs which has a AT commands for analog modems.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis3600/sw_conf/firmware/analogat.htm
Here is the url for how to apply modemcap
http://www.cisco.com/warp/public/471/recc_modemcaps.html
Now to limit the connection to 14.4 kbps and lower, you need to use
%G1%B114400%M0
above setting will allow the speed 14400 (V.32bis) and lower..
For Retrain limit you need to use %E1 and :T79 which can have max value 3 only..
317
