Modifying Attributes on A Range of Switch Ports Using Cisco IOS
I do not have a lot experience using IOS on Cisco switches. I was wondering if it is possible to modify attributes such as port speed on a range of interfaces with a single command. For example, if I want to change all 48 ports on a 3548 switch to set the speed to 100Mbps. Can I do it with a single command or must I change all 48 interfaces individually.
Re: Modifying Attributes on A Range of Switch Ports Using Cisco
With the cat3500XL series I do not believe there is a feature for this, a real pain if you need to configure port fast, speed etc.
On the newer 2950G you can use the #interface range fa0/1 -24 etc command and then enter port configuration requirements.
A little trick for Cat3500XLs:
You can use following universal pocedure for changing one parameter on multiple ports:
a) prepare a script which generates necessary commands to an ASCII file
b) telnet to the switch, conf term
c) copy and paste the commands from the ASCII file to the CLI (or copy tftp run if the file is a really long one)
Example of the UNIX script:
i=1
while [ $i -le 48 ]
do
echo "int fa 0/$i"
echo "spanning-tree portfast"
let i=$i+1
done
Milan
336
