Webcast-Catalyst9k
Module for 3745
Good Morning,
I need some help about an Hardware configuration for Cisco 3745.
I need to terminate a 34 Mbps with Frame relay encapsulation and G703 presentation on a 3745.
I am not finding any module who can perform the task.
I do not want to use a 7200 with PA-E3 module because this will increase the price of my solution.
Have you got any idea about a suitable module or solution?
Matteo
Silver
Re: Module for 3745
Have you looked at the NM-1T3/E3, if provides G.751 clear channel operation (as well as sub rate):
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps5012/products_feature_guide09186a0080108fab.html
Re: Module for 3745
Thanks.It should be supported from the SP.
184
