07-16-2003 09:22 AM - edited 03-02-2019 08:54 AM
When I reboot the 6513 I am getting a message that the modules are ndot recognized. What could be the problem?
This is a new box and all the line cards are in place.
thanks
07-16-2003 09:27 AM
what kind of modules ? are you running native or hybrid ? what code are you on ? does it recognize any modules ? Please paste in a sh ver
07-16-2003 09:39 AM
Can you please point me to process of installing software for 6513 and clearing all the config so that I can start afresh.
I will try to access the switch and get you the info.
It does not recognize any except the sup2 mod [mod 1]
I also have a switch fabric module in slot 8
What is the best version to use? Are there multiple images that I need to upload?
07-16-2003 10:13 AM
6.4(4a) which is GD should be a good software provided it supports all the line cards you have. If you need to be in 7.x, 7.6(x) is the only "live" train
http://www.cisco.com/warp/public/473/161.html
Make sure you read the release notes to check for known issues
07-16-2003 09:35 AM
The module might need a higher revision of software. Check the release notes for minimum supported software
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/index.htm
