Module/OS upgrade in catalyst 5000
I am fairly new to CISCO environment. I am trying to upgrade two switch 10 Base-TX(WS-X5012A) modules in a 3 yrs old catalyst 5000(Supervisor engine II) to a 100 Base-TX module (WS-x5224).
I found the CatOS version requirement for the WS-x5224 is a higher version than what i have.So i need to upgrade the CatOS. Can you geeks help me how i can i do this? Where from i can download the latest CatOS? What other prior steps i should pursue?
I am in need of some step-by-step documentation.Can you help me?
thanks
vensub
Below is the version info:(show ver)
WS-C5000 Software, Version McpSW: 4.3(1a) NmpSW: 4.3(1a)
Copyright (c) 1995-1998 by Cisco Systems
NMP S/W compiled on Nov 23 1998, 15:03:28
MCP S/W compiled on Nov 23 1998, 15:04:57
System Bootstrap Version: 4.2(1)
Hardware Version: 2.7 Model: WS-C5000 Serial #: 013355308
Mod Port Model Serial # Versions
1 2 WS-X5509 013355308 Hw : 2.7
Fw : 4.2(1)
Fw1: 4.3(1)
Sw : 4.3(1a)
2 48 WS-X5012A 012833053 Hw : 1.0
Fw : 4.2(1)
Sw : 4.3(1a)
3 48 WS-X5012A 012833355 Hw : 1.0
Fw : 4.2(1)
Sw : 4.3(1a)
4 48 WS-X5012A 012833376 Hw : 1.0
Fw : 4.2(1)
Sw : 4.3(1a)
5 24 WS-X5224 011682408 Hw : 1.4
Fw : 3.1(1)
Sw : 4.3(1a)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 16384K 10003K 6381K 8192K 3840K 4352K 256K 110K 146K
Uptime is 21 days, 22 hours, 15 minutes
1 REPLY
Re: Module/OS upgrade in catalyst 5000
Vensub,
Download and upgrade instructions can be found at:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_6_3/config/images.htm
Be sure to reference your hw configuration in the documentation as the procedures vary from hw-to-hw.
The supervisor card (once code is upgraded and rebooted) will load the other modules with the new code during the boot cycle.
The software can be downloaded from: (LOGIN REQUIRED)
http://www.cisco.com/kobayashi/sw-center/sw-lan.shtml
Paul
99
