Community Member
Module power down 6500 Sup720
modules 6724-SFP e 6748-GE-TX don't power up on my 6513 with Sup-720-3B.
This is the result of the "show power" command
Slot Card-Type Watts A @42V Watts A @42V State State
3 WS-X6724-SFP 125.16 2.98 - - on off
(FRU-power failed)
4 WS-SVC-FWM-1 171.78 4.09 171.78 4.09 on on
7 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
8 - - 282.24 6.72 - -
12 WS-X6748-GE-TX 325.50 7.75 - - on off (not supported)
These are the logs during the booting process
Feb 23 12:41:22.963: %OIR-SP-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure
*Feb 23 12:42:21.499: %C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (not supported)
Can someone help me?
Antonio
1 REPLY
Re: Module power down 6500 Sup720
It appears you have couple bad modules. Open a TAC SR and get them replaced if you have service contract. Refer to the following note as well
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCsb32574
1896
