modules for 4507r
Does anyone know if blades can be inserted into the catalyst 4507r while it is on, or best to power it off?
TIA,
R
1 ACCEPTED SOLUTION
Re: modules for 4507r
Blades in the 4500 series switches are hot swappable.
documented here:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_brochure0900aecd803a6c8f.html
"Hot-swappable line cards—Cards can be added or replaced without disrupting data flow in the switch."
HTH,
Bobby
*Please rate helpful posts
documented here:
HTH,
Bobby
Thanks a lot!
116
