Modules GLC-LH-SM: 1000BASE-LX/LH
I have a problem I need to connect an Administrative Seat, thus I am in the process of purchase of this I modulate GLC-LH-SM: 1000BASE-LX/LH
this I modulate this designed to work with fiber signals monoway (SM) and multiway (MM)?
as we have both means of transmicion could be re-usable?
Blue
Re: Modules GLC-LH-SM: 1000BASE-LX/LH
it is possible to use this module with SM and MM but there is a catch with MM:
MM requires a 'mode-conditioning patch cord' at all times per ieee specifications.
(SM should be recommended though)
see this link for more SFP Module info:
http://www.cisco.com/en/US/products/hw/modules/ps5455/prod_installation_guide09186a00803aa0da.html
thanks your information is helpful! on the other hand I ask to you that as much yield could have I with catalyst WS-C3560G-24PS-E to contain broadcast in this administrative seat
it can be used like species of router for this type of task?
thanks again! however according to which you say to me in your answer I can connect passcord MM and the communication is effective!
like if I connect passcord SM the communication is equal of effective?
226
