10-16-2002 06:51 AM - edited 03-02-2019 02:07 AM
We're attempting to monitor a network utilization on a port on our Cat 5500 switch using CV5.3. I right click on the port, select "monitor" and change the Category to "Interface". I see the Utilization window, however the Utilization stays flat at 0%. Is this indicator not a good measure of the network utilization on a port ?
Thanks.
_ Alex
10-16-2002 08:50 AM
Did you check to see if other ports on the switch also show 0% utilization in the CV graphs?. Also, did you install the latest version of CV device package from CCO for this Cat5K switch?
10-16-2002 09:21 AM
Yes to both questions.
Thanks.
_ Alex
10-16-2002 08:17 PM
You can use some other snmp tools or poll via CLI to see if the results match with what CV is showing to be sure that it's not a application problem.
10-17-2002 05:04 AM
Is there a way to increase the scale of the utilization reporting?
Thanks.
_ Alex
