Monitoring ISDN active calls
Can we monitor the number of ISDN calls that is active in a Cisco router through SNMP. Or is there other ways to get the info without telneting to the router.
Thanks.
Re: Monitoring ISDN active calls
Use the Cisco SNMP Navigator to find mib objects supported on your router or try a site like mibdepot.com...
Once you find a mib object, do an snmpwalk for that portion of the tree (WARNING: do not do against all snmp on a router) and see if that router is providing the desired information.
I just did a quick look but it seems that each active call gets an index row and has numerous pieces of information under them.
Cheers!
Blue
221
