monitoring tools
My company network is bulid by all cisco router and switch. since there are many routers and switch.
What tools can management it most efficient?
Thanks!
Samuel
Re: monitoring tools
Hi Sam,
There are many tools available and to name few are cisco works, hp open view, smarts etc etc.
Ankur
Hi Ankur,
If i want to monitor traffic, bandwidth. which one is the best tool? do you have relative link?
Thanks!
Samuel
Hi Sam,
For that purpose you can go for solarwinds tools
http://www.solarwinds.net/
Also check these links
http://www.monitortools.com/traffic/
http://www.flukenetworks.com/fnet/en-us/
Ankur
* pls rate helpfull post.
Hey there,
If you're on a budget of ?0, then have a look at some of the open source tools. Check out:-
MRTG
http://oss.oetiker.ch/mrtg/
Pictures
http://images.google.co.uk/images?sourceid=navclient-ff&ie=UTF-8&rls=GGGL,GGGL:2006-27,GGGL:en&q=mrtg&sa=N&tab=wi
NTOP
http://www.ntop.org/
Pictures
http://images.google.co.uk/images?sourceid=navclient-ff&ie=UTF-8&rls=GGGL,GGGL:2006-27,GGGL:en&q=ntop&sa=N&tab=wi
NAGIOS
http://nagios.org/
Pictures
http://images.google.co.uk/images?hl=en&rls=GGGL,GGGL:2006-27,GGGL:en&q=nagios&btnG=Search&sa=N&tab=wi
MRTG and NTOP and very quick to set up and are fantastic bits of software. NAGIOS is a bit more involved to set up, but is well worth the effort.
Hope that helps,
LH
Please rate all posts
Have a look at the following link too!
-Its free!!!
-Its small in size!!!
-Easy to install!!!
-Easy to configure!!!
And its pretty good too!!!
http://www.mikrotik.com/thedude.php
Hope this helps!!!
AbhisheK
Please rate all posts!!!
This is what I use to monitor bandwidth
http://www.paessler.com/
It's called PRTG traffic grapher
165
