Community Member
Montoring Dialup connection
Does anyone know software utility, which allows monitoring Cisco dialup connections, i.e. will show how many users/braches are connected through the Cisco access servers.
Many Thanks
Abdi
Bronze
Re: Montoring Dialup connection
I think you can achive this using an SNMP application like Ciscoworks. There are specific MIBS available to monitor dial-up information that you require.
Bronze
Abdi,
Cisco Access Registrar has good functionality, but I think RPMS will fit your needs more.
Heres a link.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/rpms/rpms_1-0/rpmsconf/rpintro.htm
Daniel
Anonymous
N/A
Dear Abdi,
Our campus has used MRTG( http://www.mrtg.org )for monitoring modem usage. Check it out see if you find it helpful. Yes, there is a learning curve to go through but once implemented it does generate pretty accurate graphs at the given intervals.
166
