02-09-2004 04:30 PM - edited 03-02-2019 01:28 PM
I keep hearing that you will be able to have any number of local SPAN sources and destinations and there will no longer be a 2 port destination limitation. Is this true or false? Has anyone heard anything on this?
Thanks, Dave
02-13-2004 12:17 PM
I couldn't find any document saying more than 2 number of SPAN sessions can be supported with the current ASICs. I heard it supports only 2 sessions.
03-06-2004 09:44 AM
Hi.
You need a TAP-Technologie (like a NETOPTICS TAP) to do this.
With a multiport-TAP, you can measure a Datastream with up to 8 Trace-Tools
Hope, this helps
Markus
