more then 4 fibre concentration
As the 3550 fibre only switch is not anymore orderable, is there a cheap solution to inter connect 6 fibre on one point. I did not find any fibre switch exepted the uplink connexion for the normal switches L2 (max 4).
For the SMB it is not possible to put a 4500 with fibre modules on the network because is too expensiv for a 20 poeple compagny.
Re: more then 4 fibre concentration
Whats about Cisco Catalyst 3750G-12S with 12 SFP ports?
//Mikhail Galiulin
And do you mean that a SMB compagny with 20 poeple can buy for 8K $ such a switch? For such a small compagny, they need more a 2950 class switch.
Cheers,
Daniel
94
