MS exchange (cluster IP) & HSRP -- please help!!!
from some vlans i cannot ping the virtual ip add of the exchange cluster, but can ping the nic ip add. when i do a "sh ip arp vlan 100" in router-16, i can see the entries for the all ip add, including virtual cluster ip.
when i do same in router-15, the cluster virtual ip arp entry do not show.
please help!
below sh ver of the msfc
IOS (tm) MSFC Software (C6MSFC-IS-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Fri 04-Feb-00 00:28 by lstringr
Image text-base: 0x60008900, data-base: 0x60CBC000
ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE
BOOTFLASH: MSFC Software (C6MSFC-BOOT-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router-15 uptime is 6 days, 11 hours, 18 minutes
System returned to ROM by power-on at 00:36:02 UTC Sat Jan 1 2000
Running default software
cisco Cat6k-MSFC (R5000) processor with 122880K/8192K bytes of memory.
Processor board ID SAD04281CBM
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
13 Virtual Ethernet/IEEE 802.3 interface(s)
123K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Re: MS exchange (cluster IP) & HSRP -- please help!!!
Could you post the configs
Jorge
Hi Jorge,
This was the same problem as the other one that you answered "HSRP".
Therefore it is resolved.
Thanks anyway for your response.
Sounds good.
Rgds
104
