MSFC problem
My company have a Catalyst 6506 with two supervisor engines (WS-X6K-SUP1A-2GE)and both appear to work fine althougt the system LED is red, both in primary and secondary.
Does anyone have any clue about it?
Eduardo Ribeiro
Re: MSFC problem
Do a show mod, you may see both of them faculty as the status.
a) Do a "show system" and you would probably see something is faulty.
You need two power supply for the system to come out faulty status.
b) you can also do a show test 1 and show test 2.
to see anything if faculty
Please use the following doc
http://www.cisco.com/warp/public/473/95.html
Re: MSFC problem
Make sure that both power supplies are on. If one of them is off, system LED on both supervisory modules lits to indicate this.
Re: MSFC problem
But using the show test 2, i discovered that the EOBC is faulty. How can i solve this problem?
Re: MSFC problem
Most likely a hardware failure. But you can try reseating the module to see if that helps.
Re: MSFC problem
But what is this Ethernet Out-of-Band Channel? What it does?
123
